Zbrush exit suddenly
Zbrush exit suddenly for example when i make cube / make polimash 3D (trying low 10k and hight 2milions polys)/ go to Procetion master / make few lines end PM/ go to PM a few more times and Message:
ABNORMAL TERMINATION:
Recovery file(s) stored in “Recoverd Files” and will be availble to you when you relunch Zbrush
Same situation in in Shadow Box when i increase and decrese Divide lvl
-I download and instaled Patch 2 = not result
-Reinstal = no result
-Reinstal + Patch = no result
-My vcredist is new
-GPU drivers also
My PC Config:
BIOS: BIOS Date: 10/10/12 22:17:22 Ver: 05.01
Processor: Intel® Core™ i5-3470 CPU @ 3.20GHz (4 CPUs), ~3.2GHz
Memory: 16384MB RAM
Available OS Memory: 16320MB RAM
Page File: 3505MB used, 29133MB available
Windows Dir: C:\Windows
DirectX Version: DirectX 11
DX Setup Parameters: Not found
User DPI Setting: Using System DPI
System DPI Setting: 96 DPI (100 percent)
DWM DPI Scaling: Disabled
DxDiag Version: 6.01.7601.17514 32bit Unicode
DxDiag Notes
Display Tab 1: No problems found. Sound Tab 1: No problems found. Input Tab: No problems found.
DirectX Debug Levels
Direct3D: 0/4 (retail)
DirectDraw: 0/4 (retail)
DirectInput: 0/5 (retail)
DirectMusic: 0/5 (retail)
DirectPlay: 0/9 (retail)
DirectSound: 0/5 (retail)
DirectShow: 0/6 (retail)
Display Devices
Card name: NVIDIA GeForce GTX 650 Ti Manufacturer: NVIDIA Chip type: GeForce GTX 650 Ti DAC type: Integrated RAMDAC Device Key: Enum\PCI\VEN_10DE&DEV_11C6&SUBSYS_11C61569&REV_A1 Display Memory: 4038 MB
Dedicated Memory: 1990 MB
Shared Memory: 2048 MB
Current Mode: 1920 x 1080 (32 bit) (60Hz
Driver Name: nvd3dumx.dll,nvwgf2umx.dll,nvwgf2umx.dll,nvd3dum,nvwgf2um,nvwgf2um
Driver File Version: 9.18.0013.3221 (English)
Driver Version: 9.18.13.3221
DDI Version: 11
Driver Model: WDDM 1.1
Driver Attributes: Final Retail
(Sorry for my english any idea?)
any one know whats happen?!
What version of ZBrush are you using?
Zr6
ZB4 R6 P2 is the newest release.
i download Patch 2 also you can find info about it
btw how many times Zbrush exit suddenly in your situation?!
What OS are you using? I’m on Windows 7 Home Premium Edition; About never. Quite stable and predictable here.
Windows 7 also
I hope i do not need reinstal OS…
