Zbrush - Document Import Discolorization
Hey, guys.
I’ve been trying to import a document into Zbrush to work with the ZApp to apply textures. But, when I import a BMP, JPEG, PSD. Regardless of the file format, it gets discolored to a reddish color. Anyone have the same problem, or is it only me?
When you import a document the canvas is filled with pixols. This uses the currently selected material.
If you don’t care about the imported image reacting to shadows and lighting, choose the Flat Color material before importing.
If you do care, use something else such as the Basic material. You can then modify the material Modifiers to make it look right while still reacting to anything else that you add to the scene.
Thank you! That was helpful and you solved my problem. Cheers :wink:
