zbrush distroying the uv's : normal map
hey guys.
ok so im having a bad zbrush error. me and my freind are both having errors like this
ok so i created my uvw’s in 3dsmax. and i export it into zbrush, then i do my sculpting cutting moving verts Etc. but when i want to export a normal map heres what shows up. my freinds collage doesnt have any errors like this. so its probobly a problem on the version. but i have the latest and its still having thie error
im sure errors like this wouldnt happen on MacOs systems but im asking if any of you have a solution for this problem. if not i hope the coders would fix this on there next update for zbrush.
or i could be the person making a mistake in zbrush if so plz tell me. i would love to continu using this software for texturing and to create normal maps
anyway. heres what comes up when i try to make a Normal map. as you can see its got problems any help on this problem would be much apreciated
See my post in this thread.
thanks alot for your reply ill see if it works and my freind will too.thanks
