Zbrush displacement maps are blank!
I used this guide ( http://www.zbrush.info/docs/index.p…placement_Guide ) and did it their way using MD3 but the maps are just nothing but grey, doesn’t work…
Any ideas? I’m using the quick code provided in that guide.
What subdivision level were you on when you created the map?
1… is this wrong?
I have max 8 subd levels.
Hi, still having problems. Just made a completely new model and my displacement maps are still blank.
scrub that, they’re showing up now… not sure why…
still, i can't seem to get a LOT of the detail onto my object, wonder what i'm doing wrong now =/
if i put the alpha gain up to 40 and offset to -20 then i can see a lot of the detail, but i thought it would generally be around… 2.2… am i missing something?
I am getting artifacts also.
