Hi!!
Finally I decided to do it in V-Ray, just because i’m more familiared with.
However I will pick up the file again and try making changes in some settings as you propossed. Thanks.
My settings were:
Adaptative ON, tif file (i’ll try .psd, and .map, probably will work better) and i didn’t altered the midrange in displacement map at zbrush. probably that solves the problem of the 2.2 -1.1 settings i can’t get.
did’nt altered nothing at photoshop.
I worked in maya 2010. Now trying 2011, it’s ok and works fine with v-ray 1.5, so I download the trial. By the time i posted this thread i was using Maya2010.
I use approximation editor. Actually i achieved some better results just activating FEATURE DISPLACEMENT from maya and only using SUBDIVS APROXIMATION for mentalray, instead of using subdivs and displac.Aprox. Don’t kknow why, better results with maya built-in displacement with mentalray subdivs aproximmation. Settings were Spatial, and 4 iterations (same as smooth levels i worked with at zbrush). Now I bought a better machine (older was asking for retirement) and can achieve more subdivs level at zbrush and iterations or subdivs (don’t remember the setting name) at 5 or 6.
Resuming, I’ll try some of this changes and I bet it will be a noticeable improvement. I’ll feedback in some days.
Thanks Very much.
