zbrush camera weird problem
when i try to render a large document, 4096x4096, i hit BPR and i go to save out the render and i get a tiny render of the object with the 4096x4096 as only the canvas size, so it is not reacting to where i have the camera( my view) is there anything im doing wrong? right now i keep getting closer to the object and hitting BPR to see how big it is over and over till its the right size for a work around. this is fine for now but i really want to know how to fix this. thanks
After you change your document size, use the ‘Zoom’ button on the right shelf to zoom out until you see the document edges. Then draw and scale your model to fit. When you change document size, it doesn’t automatically zoom out on it’s own.
thanks !!
