Zbrush brush question
Is there a brush in zbrush that will allow me to draw and if i go over the same area again it will not raise?
For instance when i use say the “standard brush” with zadd it will raise the area i draw across and if i take my pen off the tablet and redraw over it will raise further.
I am looking for a brush that will allow for this not to happen.So for example i can draw on a mesh,rotate the model and carry on drawing from the same point without any difference in height.
I know you can use Projection presets to get the desired result,just looking for an option outside of projection master
thanks
Yes, the Layer brush, provided you store a morph target first (press Tool>Morph Target>Store MT).
