ZBrush and 4 K monitor res problems
I can’t get the resolution to work on a 4K monitor. When I load a tool from tools and enable edit they look fine. But tools from the toolbox look giant and all pixilated. I’m not sure this is a monitor/resolution problem. I didn’t have this problem before with a regular monitor. My old projects also open with the same problems. I’ve spend hours trying to figure it out with no luck.
Hello @marcos9999 ,
For technical assistance with ZBrush, please contact ZBrush Support. This will require information about your License and system, and cannot be conducted publicly over the community forums.
I’m going to close this thread now to eliminate any expectation of assistance here, and encourage you to go where you need to go for assistance with your problem.
Thank you!
