From the wiki
“Note: ZBrush alphas are 16 bits in depth, which simply put means that they can produce much smoother gradations in gray, and hence wherever they used. Some other programs are limited to 8-but alphas, which can produce noticeable ‘stairstepping’ artifacts.”
“Note: Some image file formats do not support 16-bit grayscales. If you load such files, you may get the stairstepping effect described earlier. When using external programs to create alphas, try to use one that offers 16-bit grayscales.”
Please provide a list of some graphics programs that addresses second note.
I am finding some programs are opening 16bit files but saves as 8bit in files
TIA
John
