Zbrush alpha?
Hey guys, you’ve helped me so much, and now I have a problem I’m a bit ashamed of…I want to make an alpha for my model so I could erase it’s background in photoshop and repace it with a new one…how can this be done in zbrush and can it? I did the turn off color of all subtools and render out with the flat material, bu I know there has to be an easier way. And by doing this not all of my subtools are bright white as the one selected so I have to adjust them in ps and my mask gets rigid edges by doing it.
Please help!
Cherub
Hey there,
the easiest way should be going to the render palette and
use flat render.You also can try the mrgbz-grabber or the
canvas grabbing (alpha palette).
Keep going,J.
Hey, I forgot about this one already, hm, I’ve tried it an it doesn’t work makes some of my subtools lighter and the other darker, and I need a one shade sillouette. I can’t find the other options you mentioned under the alpha :confused:
