plz. help
plz. help
I guess you mean you want to move the cube? If so, you need to place the Transpose line right across the cube first.
The cube has to move with the transpose line, but only the cube moves
That’s normal behaviour. The transpose line stays put.
In older versions of zbrush, objects and transpose lines seem to move together. Is it changed?
It was like that in 4R7. I don’t remember before that.
Thank you for your answer
