i happen to come back to help others who wan’t to get this to work, im on linux mint.
1.you need to install zb in 32bit wine, i highly recommend “playonlinux” to manage wine.
the reason is zbrush seems to fail the install when done on wine64.
2.in the wine configuration>graphics, check emulate a virtual desktop, then choose your resolution.
3.start zbrush, if it prompts it can’t find a tablet, just press ok and wait for 1-2min it should start.
couple of things doesn’t work:
1.decimation master - fails to precompute, can be cancelled by esc
2.noisemaker edit window. - this one is fatal
3.quicksave doesn’t overwrite if maxsave is exceed, just delete the content if its full
4.some reports GOZ fails, i have no idea im using houdini which doesn’t have any GOZ so i just deal with OBJ
if you have no idea about WINE, just install PlayOnLinux you don’t have to fiddle in the terminal.
i have been testing this in a month, seem to work nicely
hope for a true linux variant, goodluck
