Zbrush launches maya each time i hit the GoZ button instead of updating the one is already opened, this is when i am not running the program as administrator, the problem is that i don’t have permission to use this computer as an administrator, so i need GoZ to work as is supposed to, i did “force re install” and followed every step in the documentation many times now, and did not work, It only works fine when I run Zbrush as an admin tho.
Does any one have a solution for this, I did my try and searched the forum but did not have luck, your help will be appreciated, thanx in advance.
small_orange_diamond
anyone?,
sorry to bother you aurick, but could you provide any guidance on this?
Some file needs a routine to see if Maya is running, if, update scene; if not then launch and load etc. That would be my guess.
Hello, yeah probably some editing on the scripts is needed, but I am not really familiar with tweaking those
Hello everyone, I have a different question now, if nobody can help me via these forums, no User , no admin, so what’s the next step?, submit a support ticket? or just assume there is no way to solve the issue?
I don’t have MAYA. Never used it. Maybe you can set it up so only one instance can run at a time?
hello, thank you for the input on this, I am afraid that won’t be a good solution for me, since I often tend to work with two instances of maya running.
but thank you
***12375;***12423;***12358;***12364;***12394;***12356;***12290;
