Hello,
I get an error message each time I try to use Projection Master in ZBrush 4R5. How can I solve this problem, please ? I join a screenshot showing the full error message.
Thank you
Hello,
Thank you
This is a known issue which will be fixed in an update. I’m afraid I don’t know when that will be.
Does it means that meanwhile Projection Master can’t be used ? Is there a way round to achieve the same thing ?
Sadly, you can’t use Projection Master at all in 4R5.
If you have ZBrush 4R4 installed then perhaps you could use that. Alternatively, if you are wanting to paint your model only (no deformation) then you could use ZAppLink to send the texture to Photoshop, or you can use the PaintStop plugin:
I’ll try with ZBrush 4R4 or PaintStop. ZAppLink seems to have also a problem in ZBrush 4R5. It generate an error message as shown in the screenshot :
Great, thank you
