ZBrush 4R4 Update 2 is Ready
Update 2 is now available for ZBrush 4R4
This update addresses the following:
  • Fixes inconsistent behavior of customized UI buttons and palettes.
  • Updates HD geometry read/write functions.
  • Adjusted ‘Simple Brush’ rendering of applied alpha.
  • Option to turn off LightBox ‘Open at Launch’ setting is now enabled.
Note: All users (both Windows and Mac) should update to this latest version of ZBrush.
How to Update
  1. (PC Users, Only) Browse to your ZBrush 4R4 folder and delete updater.exe, if present. Do NOT delete ZUpgrader.exe!
  2. Run ZUpgrader or launch ZBrush and click Zplugin>Auto Update>Check new updates.*
  3. Follow the on-screen instructions.
  4. When update completes, launch ZBrush and activate. The ZBrush title bar will now say “ZBrush 4R4 P2”.
*Note: For some users, depending on user permissions and network security, the “Check new updates” button may return a script error. If that happens, simply run ZUpgrader in your ZBrush 4R4 folder.
Happy ZBrushing :slight_smile:
