ZBrush 4R3 window size
Is there a way to make ZBrush 4R3 open to maximized window size? I have to restore down and then maximize every time Zbrush is started. And…is there a setting to make ZBrush open with lightbox closed?
Thanks,
Matt
1) Delete D:\Program Files (x86)\Pixologic\ZBrush 4R3 FL\ZStartup\ConfigFiles\ZBrushWindowStartupSize.cfg. This resets ZBrush to launch maximized.
  1. Preferences>LightBox>Open At Launch, however that feature is not currently working as intended. Instead, I believe you could add a command for [IPress,5691] to your StartupZScript.
