Hello
This is compares the two versions screen.
What is the workaround for this problem?
Hello
Zproject brush currently does not appear to be transferring color as intended. It still functions for displacement.
For painting color from a 2d backdrop or texture like you’re doing there, Spotlight (Select texture>Texture Palette>Add to Spotlight) largely replaces Zproject, as it is a much more powerful tool for that.
http://www.pixologic.com/docs/index.php/Working_with_Spotlight
http://www.pixologic.com/docs/index.php/Spotlight_functions
For Projecting color in 3 dimensions from another 3d model, use the ProjectALL feature in the Subtool menu with MRGB pressed on the top shelf.
