Also, in your display setting if you turn down your resolution a notch or two momentarily it will “snap” the window to your display res. Then, set the display back to your original settings and the snap should stick. You can then rearrange and save the UI.
As for getting a new monitor to use the UI, holy cow! thanks for the kind words!
