ZBrush 4R2 - ProjectAll (Solved)
Hello
This is compares the two versions screen.
What is the workaround for this problem?
My System Image:
http://www.zbrushcentral.com/attachment.php?attachmentid=278198
Increase the DIST slider next to ProjectAll, until you get the results you want during projection. The default values in R2 usually require some tweaking. The target mesh must be high enough resolution to hold the incoming detail.
Thank Spyndel.
However, I have the same test.
In this case, is to show the same results.
The target sphere looks too low poly. Subdivide it again.
Increase the Dist slider.
It works, see:
The default value of ZBrush 4 is 1.
The default value of ZBrush 4R2 is 0.02.
Thank Spyndel.:+1:
