Zbrush 4 Polypaint to texture problem
Hey there,
I applied a texture, polypainted from texture and edited it…now I want to make it a texture again and clicking New from Polypaint gives me the texture map in the toolbar on the right (in zbrush4) but its not showing up in the texture box on the toolbar in the top nor on the left in the textures…how do you get it saved out if its not showing up?
If I make a new texture and click New from Polypaint its not showing up in the texture picker window either…
Its driving me nuts >.<
Once you have created the texture, Tool > Texture Map > ‘Clone Txtr’ will put the texture in the Texture menu where you can export it. The other map creations work similarly.
Thanks I will try it out.
So you mean click New from polypaint and then click clone?
Awesome its fixed ^-^ cant believe i missed that…Thanks alot <3
