zbrush 4 plugins
hi guys! i wonder how can i use multi displacement export 2 plugin in zbrush4
i have set plugin correctly. but it has been occured error when i execute it. doesn’t MD2 support zbrush4? is there other plugin for zbrush 4? plz reply ㅜ _ ㅜ
You can’t. The only plugins that are compatible with ZBrush 4 are here: http://www.pixologic.com/zbrush/downloadcenter/zplugins/
Plugins created for earlier versions will not work with 4.
Is there a reason you’re trying to use MD2 when MD4 is much more feature rich and supports multiple SubTools as well?
