I am trying to render a 32 bit map in renderman for maya 3.
Last time I used renderman for maya it was version 2, and it was with zbrush 2. Setting the alpha gain/offset to 2.2 and -1.1 respectively normally resulted in a hassle free render.
I am using a 4k map, tried both smoothed and unsmoothed. It seems like the problem is associated with differering subdivision algorithms as descrbied here, in the second last post.
Basically it appears that the displacement is not quite occuring in the correct place, so that raised edges for example are slightly offset from the raised part of the base geo.
Has anyone used maps from z4 with renderman for maya 3 and found a workaround?
Any help appreciated,
thanks,
gubar
