Hi, I have a question about generating normal map in 3.5r, should I just use the default normal map penal to generate map on the level 1 map? or I remember there was a plug-in called zmapper, is it still being used? If it does, is the normal map it calculates better than the default Zbrush’s one?
Many thanks for someone who can answer me! :lol:
There is no ZMapper for zbrush 3.5 (see the knowledgebase article in the Support Center)
Is the normal map better?, depends who you ask as there have been numereous discussions about this in various threads.
Richard
