After giving Zbrush 3.5 R3 a try, I realized something peculiar while working in the Projection Master: the good old Polyplane tool has been ninja altered.
In 3.1, you could drop into Projection Master, select Polyplane 3D tool and easily apply texture and alpha effects in your lefthand menu:
Not only do I have to go to Tools>Texture now to apply the texture to the Polyplane, but the Alpha section no longer has any effect. Those who would suggest that I use the Simple Brush should be reminded that unlike the Polyplane, the Simple Brush does not allow you to rotate your strokes.
I would appreciate anyone’s help on this matter. If there is a way to apply Alphas to 3D Tools in Projection Master, please tell me.
