ZBrush 3.5 RC2 on XP/Seven 64
I´m trying to convert primitives in Mesh, but the command is not working. I insert a primitive, then I enter in Edit Mode and click in Make Polymesh 3D, but nothing happens. So, I try to sculp and a message saying I must convert to Mesh appears.
Is this some incompatibility with 64 bit systems?
Cheers,
I run ZBrush without issue on a 64-bit system.
Have you installed any plugins from earlier versions of ZBrush?
No plugins, aurick…
Try deactivating ZBrush (using the Zplugin palette) and then deleting its folder. Reinstall and see if the issue is resolved.
