Anyone have the same problem? Whenever I want to load a tool or saveas a tool zbrush will crash with a pop up saying zbrush is unable to properly complete this function.
using windows 7 home premium 64bit, 4Gs ram,
WEIRDDDDDDDDDD
WEIRDDDDDDDDDD
It sounds like you have Preferences > Performance > Auto File Recovery enabled.
The function apparently does not work in Windows 7. I had the same problem with Vista 32 bit but Vista 64 bit works fine with Auto File Recovery enabled.
I just checked that, its grey which equals not enabled i assume. any other ideas???
Does it have to do with windows 7 admin permissions in the tools folder or sth???
zbrush 3.5 is installed in my c:/programs(x86) which is the 32 bit part???
Not sure what it could be. I am running Vista 64bit and have not really been following zbrush issues in windows 7, sorry. Has it just recently started crashing or have you never been able to load/save?
There used to be an issue with network drives. So you could try enabling Preferences > Misc > Use ZFolders and then pressing loading or saving a tool. Use ZFolders will open the file dialog window in the relevant ZBrush folder, i.e Tool > Load will open in the ZTools folder.
Are you using Adobe Acrobat 7 ? I just read a post by Support that mentioned an issue with that version which could cause problems with file dialog windows.
ZBrush being in the c:/programs(x86) folder should not be a problem. But you could try running ZBrush as administrator just to be sure.
I have never been able to load/save a tool, I just checked my USE ZFOLDERS has always been enabled. And I run Zbrush as admin. I edited the compatibility in the properties suggested in the Troubleshoot notes.
I do not have adobe acrobat 7, I have acrobat 9 installed, not running in the background either.
any more ideas??? ZBRUSH GOD HATES ME
Hi
Did you check compact memory in preference menu if not pls check and configure it immediately.
Tallooriravi
Hey mark,
what should my compact mem settings be. i have 4 gigs ram, gforce gt 240m vram 1gbs on my Asus laptop.
THANKS!
i meant tallooriravi on my last post haha sorry
