Zbrush 3.5 Clipping Plane
Where from the menu do I fix the the settings where I’m able to see the full model such as 3.1. Can’t find any info on this.
[camera.jpg](javascript:zb_insimg(‘172477’,‘camera.jpg’,1,0))
I suspect you accidentally baked the layer prior to drawing the model. This converted the empty space of the layer into pixols, and so when you drew the model ZBrush placed its center on those pixols.
What happens if you press Ctrl+N to clear the canvas?
It’s like this every time I open up 3.5. If I press CTRL+N and draw I get the same result. In a front view everything behind is hidden.
I still need some help here. I haven’t disappeared. I figured 3.5 did this naturally but I see there may be something wrong. Anyone know whats the problem?
ALSO!
I cannot import models from 3.5 to 3.1. Is there a special way you have to setup up the ztool in order to do this?
I would appreciate some information regarding these issues please. Thanks.
In the Preferences>Picker submenu make sure the AutoFront button is switched on. Then store the configuration (Ctrl+Shift+i).
You can’t open 3.5 models in 3.1. The format is different. You’ll have to export the highest subdivision level as an OBJ and then import.
