Zbrush 3.2 texture not loading in mac osx
I am new to zbrush and currently reading Eric Keller’s Introducing ZBrush.
I notice some of the instructions in the book do not work (is it because the exercises in the book are done in a pc environment?), especially loading textures from the Texture Palette to any 3D polymesh, which should be a simple task. Can anyone tell me if I should re-install ZBrush or is there something that i am not doing right.
the only time i can load texture is thru the Texture Map sub menu in the Tool Palette.
thanks and regards,
Elden
That is precisely how you need to apply textures in 3.12 and higher. Because textures are now applied to individual SubTools rather than to the whole model it is no longer possible for you to apply a texture through the Texture palette. You must use the Tool>Texture Map menu. Please see the link to the PDF documentation, in my signature.
thanks you for that quick reply. i was getting dissappointed with my study. that gives me a better light.
