Zbrush 3.12 Pojection Master
I’ve been working on painting textures for a model of mine in zbrush 3.12 on the mac. I dropped the model in the projection master and took a good bit of time painting in it, but when I picked up the model none of my painting went with it. I don’t know if there is an issue in the projection master or I missed a step in the process. I would greatly appreciate some help on this.
If you’re polypainting, make sure to fill the object (Color>Fill Object while Draw>Rgb is active) before you use PM. If you’re texture painting, make sure a texture is actually assigned to the SubTool you’re working with, and that the model has UV’s.
