Zbrush 3.12 OSX - displacement map not migrating to the Alpha palette after creation
I can’t see my newly created displacement map in the Alpha palette, therefore I can’t export it - I’m running the newly released 3.12 for OSX - any help would be appreciated.
Thanks
Under Displacement Map there is a button called Clone Disp. It copies the displacement map into the alpha palette.
Much appreciated - I’ll give it a try. Do you know if this is a work-around or a newer improved way of doing it in the 3.12 version?
Not a clue. Hopefully they’ll post documentation soon.
I’m working on a larger post, but I’m having a terrible time with my imported UV map; getting a ton of crossing lines and such that just weren’t present in the original map (nor are they when I bring it back into modo.)
Anyone else experience UV map problems?
PS. you don’t need to export your map separately if you export as OBJ it will save the displacement for you.
