hahaha… love the signature, neilford!
About 95 percent perfect… I have some questions about those 5%. Maybe it’s only me who have some problems with rendering and crashes. This takes more as 5 percent. Maybe I overlook something you can tell me.
When I open that basic head, I can make edgeloops where I want. When I delete something in the subtoolsmenu, the edgeloops do not funcion anymore. Also after exporting only the head and importing it again. In the old version (2) the were no problems with this tool.
Using the decobrush I need to change the preferences by deactivating MultiDraw. Does ZB3 support my 8-core?
Working with ‘Draw Polyframe’ gives a real bad screenredraw.
And some more… Let’s make it 80%
baz, the edgeloop issue has been discussed here:
http://www.zbrushcentral.com/zbc/showthread.php?t=63854
you didn’t say what was wrong when you import.
that deco brush problem is on the pc 3.1 as well, i wonder about the cores myself.
also i’ve seen the redraw issue myself on 3.1 and have seen others repost. hopefully all this will be sorted by 3.5
thanx…neilford
@Spaceboy, thanks. After posting several times the question about the edgeloop-tool you brought the answer.
I am sure the next update will be better.
… I can save only in .ZMV
I can’t save in .MOV
Maybe someone have the same problem?
Maybe someone can explane me what can i do?
Thanks
Wol, the.zmv format is so you can add more to the video if you wish, once you save in .zmv you can use the EXPORT button to output to .mov.
EDIT: apparently this function has been removed for the time being see here:
http://www.zbrushcentral.com/zbc/showthread.php?t=63623
Where is export in ZB3.12?
The only export I can see, is in “Document” menu but is only for a single image.
… the ZMV file made in ZB3.12 are unusable in ZB3.1
Why? At the moment I have use jing to make a screencast of my ZMV file.
In this way my friends can see the turntable.
Is this the only way?
Hey All
I just got Zbrush…5 min from purchase to installation,amazing
And it seems to work great…but i wonder about some issues
im pretty new to zbrush,so its maybe a dumb dumb question
my A hotkey to preview Zspheres dosn´t seem to work,i have to push the preview under Adaptive skin to see the mesh?
No preview image of the Ztool…when loading one,whats up with that?
3.and my Undo somtimes dosn´t seems to work either?
these are just some issues i got for now,wonder if anyone here have the same problems
besides from that,i looove Zbrush,
ZBrush has issues maintaining it’s focus when you switch apps. Make sure you see the ZBrush name in the menu bar.
Yay! Amazing how all problems are forgotten when that dark gray interface springs to life!!!
Finally got there, and yes, smooth, effortless installation. There are more differences than I thought and a lotto get used to, but it’s so nice having stuff that Windoze folks cant have! Oooh you should see that Zooom - All the way in! How could one live without it???
Mwuahahahah!
Ok spaceboy I have found the right turnaround. Make a screencast for the moment is the only way.
I have used jing to make a screencast of my ZMV file:(
ZB3.12 is a transitional version to the 3.5… …is a little bit like a beta version, the only difference I can see is the stability.
Awaiting the Mac 3.12 trial release, any info appreciated?
