The test - the image is not rendered and the imported model has not been Geometry divided or HD Geometry divided.
Here are the steps:
- download EleFont here http://www.armanisoft.ch/webdesign/elefont/Elefont.html (free)
NOTE: ZBrush will not open the dxf file so step 2 (the program was made for Bryce) and the program only allows lines not multiple lines (as far as I know). Also allows you to pick fonts from what you have on your computer.
BIGGER NOTE: If any of you ZBrush 3.1 Guru(S) can figure out how to import the Elefont dfx please let us know (TIA)
- download the free Bryce 5.5 Daz3D and import the dfx model
THEN:
Select only the DXF Mesh (no primitives, ect).
Hit the little “E” next to the object(s), which opens the Smooth window.
Now type Control + D (Command + D on the Mac).
In the File Selector name it and select “Wavefront OBJ” from the popup and Save.
- Open ZBrush 3.1 and import the obj model draw it onto the canvas then click edit mode and use rotate - scale - move tools
