zbrush 3.1 & maya 2009 Displacement Map Issue
I am using maya 2009 and using zbrush 3.1 to generate a DP map for my model. I have come across problem which I have used up 1 1/2 days to solve, but still to no avail. The DP map not working at all for my maya model. Here is what I have done along the way:
1)subdivided my model n sculpted in zbrush.
2)go to the lowest subdiv and generate my 16bits DPmap. The DE option all set up and exported the map.
3)b4 plugging it in maya, I test render it in zbrush, just to be sure. Subdived the obj model to the previous levels of divisions and test out the alpha map. All the details come up.
4)up to this stage, everything is good.
5)changing Maya renderer to MR, set up the approximation to: Parametric and N Subdivissions to 6. Change the MR render preference to : use maya-style alpha detection on file textures
7)plug in my dp map in Blinn SG and set the Alpha gain/off to an initial value of 1; -0.5
8)When rendered, the details not coming up at all. I have these in the Output Window stating:
" invalid TIFF directory; tags are not sorted in ascending order.
TIFFReadDirectory: Warning, wrong data type 1 for “Software”; tag ignored. "
I put my DP map.tiff in the source image directory, does it has anything to effect the result?
Pls give advice and help up! I am confuse as what to do next!
Thanks a lot for yr time.
I increase the N Subdivission in MentalRaySubdivApprox from 4 to 6, the
" triangle count (including retessellation) : 25804 "
still remain the same in Output Window(both 4 n 6). I thought this number suppose to change whenever I increase the N Sub? Is it rite?
It finally works after changing the approx value and many tries! Now all da details pop up rite where I want them :smiley:
