Hi. I have an issue with Zbrush 2021 where after a small amount of time, zbrush will no longer update my view while my mouse is pressed down. So for example If I want to rotate the view around my character. I will only see the camera update of my rotation once I let go of the mouse press. Or if i’m zooming out. It will update once I release the mouse. So I cannot see any changed while zooming.
I’m using latest graphics driver, and 2020 works just fine.
Hello @Stefano_Giusio
I can’t causally reproduce the issue you describe. I’m afraid you’ll need to contact Pixologic Support. The community boards wont be able to help you with system specific technical issues.
Good luck!
Alright, Il contact support directly, thank you =)
I’m having the same issue! specifically when I’m using double monitors.
I will. thank you
Try to disable Windows Ink in your tablet settings or windows settings. That solved the issue for me.
I had the same problem and tried this, it worked. Thanks @Stefano_Giusio . Disable windows ink workspace
