I got a problem with Zbrush 2020 when I try to start it. It displays a few message boxes like this one
After closing all the popups I still can’t use the app. I tried to desinstall to no avail. Any idea?
Thanks!
Thanks!
Hi @joebount
Sorry you’re having some trouble here.
One possible issue–Zbrush requires a C Drive on the computer.
One note: Be sure to disable any Antivirus during the entire installation process (download to install)–it’s a common source of installation issues. Be sure to re-download a fresh installer–they can become corrupted.
Otherwise this error seems to indicate a problem with the path Zbrush needs to use for virtual memory. This is probably going to require you to make a Support Ticket and provide them with the system info they will need. They are better equipped to troubleshoot those sorts of issues.
Thanks for the answer.
I do have a C drive on the computer (but I didn’t install it there). Also I forgot to mention that I manage to launch it once (the first time) and loaded my prefs and keymaps from 2019.
After that no luck even after reinstalling the software. :-/
The particular folder that you are using for your scratch disk directory either doesn’t exist, the path to it is incorrectly formatted in the text file designating the path, or folder permissions are insufficient for ZBrush to be able to write to it. The Everyone user group should have Read & Write permission for the ZBrushData2020 folder and enclosed items.
Ah ok. It must have happened when I copied my prefs from 2019 to 2020. Do you know by any chance where these values are stored for 2020? I deleted the 2020 folder but I still get the error. It must be some remnants somewhere.
Thank you!
Unfortunately not. I have been sticking to the previous version for work reasons and haven’t had the opportunity to have a look. I did have a look at the time but wasn’t able to find the files location
@aurick any chance you could point us to a solution please?
For Windows, you’re looking for C:\Users\Public\Public Documents\ZBrushData2020. For macOS it would be /Users/Shared/ZBrushData2020.
That folder is created when ZBrush 2020 is first launched. If it is not created then something in your system security is preventing ZBrush from doing so. For Windows, my recommendation in that case would first be to right-click on the shortcut for ZBrush 2020 (or directly on it in its installed folder) and choose “Run as Administrator.” This will launch ZBrush with elevated permissions, hopefully allowing it to create that folder. Once created, you don’t need to do Run as Admin anymore and it’s generally a good idea to not do so.
If Run as Administrator doesn’t work, the next approach is to simply create the ZBrushData2020 folder yourself, in the correct location. Then ensure that the Everyone user group has Read & Write permission for that folder and its contents. From there, ZBrush should be able to make use of the folder when you next launch it, creating the remaining files that are necessary.
If you still have issues, please submit a Support ticket, using the ZBrush Diagnostic Utility: See Here
Thanks @aurick,
below some error messages I received even after I made this folders:
Unable to save file
!:/users/Shared/ZBrushData2020/ZBrushScratchDiskPath
Unable to save file
!:/users/Shared/ZBrushData2020/ZStartup/ConfigFiles/ZBrushID
Unable to save file
!:/users/Shared/ZBrushData2020/ZBrushQuickSavePath
Unable to openfile
!:/APPLICATIONS/ZBRUSHOSX 2020/ZResources/Images/Txtrs/Texture Off
Unable to openfile
!:/APPLICATIONS/ZBRUSHOSX 2020/ZResources/Images/ZLogoForNotes
and so on…
I contacted the support, they advised me for clean install but I didn’t made any difference. Waiting for feedback…
Then even though you created the folder, it doesn’t have the necessary permissions for ZBrush to be able to write to it. Make sure that the Everyone user group has read&write permission for that folder and contained items.
@joebount @aurick Found a way around.
Used somenbody’s backup (time machine for mac) with an older OS. Installed Zbrush an than updated the OS to Catalina. Now it’s running thanks to those folders who where created when the older OS was installed.
for god sake, i have same problem with 2020 01 new version.
tried re-installation
install in D drive
i surely disabled defender apps before download and install.
but can’t work. so frustrated. T^T
did you solve the problem?
The ZBrushData2020 folder is created when ZBrush first launches. It is not created by the installer itself.
These errors are always caused by one of two things:
Now try launching ZBrush.
If you still have issues, please submit a support ticket and include your ZBrush Diagnostic Report.
Thanks!
Hello! I read this forum. Did everything as you wrote, but the result is zero. These errors about which other people wrote do not disappear. Zbrush does not start.
I’m very upset that I can’t work in zibrash. What should I do?
When you are using a mac, you must downgrade to an older OS, install zbrush and then you can update your os again.
i ve got a rrsponse from zbrush support as follows;
What I would like you to do is to perform a clean installation. This is not the same thing as a regular uninstall/reinstall. It involves removing some files manually.
Follow these steps to perform a clean installation and get ZBrush activated:
but still i failed running zbrush. bit if i turned the windows active virus detection funcion off, then it goes open. but some hours later the function tirned on automatocally somehow, then zbrush cannot save any files.
I had this problem today. On Windows 10 it seems Windows Security is causing this problem. Zbrush’s permission to write on the folder has been removed. To solve it:
Go to Windows Security
Virus & threat protection
Ransomware protection
Manage ransomware protection
Allow an app through Controlled folder access
Then add Zbrush as an allowed app by going to its installation path and adding its .exe file
Cheers.
i had the problame like that. have you tried uncheck read only in properties.
Thanks this resolved an issue I was having with exporting my .fbx files.
HI GUYS!I just solved it, just create the “VMEM” folder in the installation directory, and in this folder create “ZBrushData202x”,
Then start the program… Waiting for a miracle
