ZBrush 2018.1 Now Available
ZBrush 2018.1 is now available for download.
This patch is a free update and is highly recommended for all users. It includes a number of changes for improved stability in ZBrush 2018:
NEW
  • Added various changes to increase ZBrush sculpting and navigation speed.
  • Added ‘Go To Unmasked Center’ button for use with Gizmo3D center option.
  • Added ‘Uvb’ and ‘Uvbt’ (UV-Box and UV-Box tiles) UV map creation options.
  • Added option to export Smooth Normals with OBJ files.
  • Added ZModeler Inset proportional option. (A Single Poly only. CTRL modifier)
  • Added a warning when loading custom brushes with auto-masking enabled if Sculptris Pro is active.
  • Added a MatCap Red Wax material so it will no longer be fully replaced when using ‘Save As Startup Material’.
UPDATES
  • Fixed Groups Border weighted smooth mode (Smooth Groups Brush).
  • Fixed iCloud Photos shortcut issue.
  • Fixed GoZ Photoshop Crash.
  • Fixed GoZ Max has been updated to work with 3ds Max 2017, 2018, & 2019.
  • Fixed double clicking not opening ZPR or ZTL files on the macOS.
  • Fixed issues with tablet pressure on macOS.
  • Fixed ZRemesher density control with Polypainting on macOS.
  • Fixed CTRL + Drag duplicated crash when using the Gizmo3D.
  • Fixed issue with geometry position sliders staying active when inputting values.
  • Fixed issue with lightbox not opening with large number of loaded brushes.
  • Fixed issue with VDM brushes when applying with textures.
  • Fixed ‘Draw Transformation Border’ not storing with Config.
  • Fixed ZBrush not responding after restoring from minimize on macOS.
  • Fixed typing with a French keyboard on macOS.
  • Fixed importing of PNG files on macOS.
  • Fixed custom UI not storing when in full screen mode on macOS.
  • Fixed Screen Saver from activating when ZBrush is launched on macOS.
  • Fixed computer not sleeping when ZBrush is launched on macOS.
  • Fixed issue after UI is saved in window mode on Windows.
  • Fixed issue of UI not being saved in fullscreen on secondary monitor on Windows.
  • Fixed UV Planar smoothing UVs when applied. Now smoothing will only take place when SUV in the Tool>Geometry is enabled.
This list is not comprehensive. It shows only the most significant updates. Other, smaller updates have been made as well.
To learn more about ZBrush 2018, click here.
Please read the following instructions carefully in order to determine the proper upgrade steps for your system.
If you are upgrading from ZBrush 4 or below, please follow the full instructions here. You will automatically have ZBrush 2018.1 from the outset.
If you have already upgraded to ZBrush 2018, with ZBrush closed please browse to your ZBrush 2018 folder and run the ZUpgrader application found there. (Do not run “Update,” “Updater” or anything else. You must run ZUpgrader.) This will update your ZBrush 2018 installation to 2018.1. You will not need to reactivate ZBrush after updating.
  • If you encounter issues with the ZUpgrader -- or if you simply wish to have a completely fresh ZBrush 2018.1 installation -- please uninstall ZBrush 2018 and then download the most current ZBrush 2018 installer from your [My Licenses](https://pixologic.com/my-licenses/login.php) page. This page will always give you the most current installer, which at this point is the ZBrush 2018.1 installer.
  • Remember that this is a brand new installer. (Both the patcher and the stand-alone installer.) This means that it will be misidentified as malicious by many antivirus applications. It is STRONGLY recommended to temporarily disable such programs before using ZUpgrader or the stand-alone installer.
If you have floating licenses, you cannot use the updater. Your company's IT manager will need to submit a Support ticket to request the update. [See here](https://support.pixologic.com/Knowledgebase/Article/View/232/64/upgrading-floating-licenses-to-zbrush-2018).
Happy ZBrushing!
ZUpgrader says there’s no new update. Maybe it’s a delay?
Please follow the instructions in the bullet point:
If you encounter issues with the ZUpgrader – or if you simply wish to have a completely fresh ZBrush 2018.1 installation – please uninstall ZBrush 2018 and then download the most current ZBrush 2018 installer from your My Licenses page. This page will always give you the most current installer, which at this point is the ZBrush 2018.1 installer.
Mac OSX 10.13.5
Also…
“ZUpgrader” is not optimized for your Mac.
This app needs to be updated by its developer to improve compatibility.
(needs to be recompiled to 64bit)
Win 7 Pro SP1
Mine says “Update Not Available”?
The ZUpgrader wouldn’t work, so I downloaded and tried to install … no luck. Damn dmg file wouldn’t mount. Any other Mac users having this issue? Wish these guys would figure out a better way to update/upgrade or at least give us something that works as they say it should. Frustrating as hell!!! :angry:
For all support with installing the ZBrush 2018.1 Update, please submit a Support ticket at https://support.pixologic.com.
Reminder: If you are unable to use ZUpgrader, you can download the stand-alone installer from My Licenses.
Thank you!
