<center><font size=5><font color=#FFA000>ZBrush 1.51</font> Keyboard Shortcuts</font></center>
In order to make it as easy as possible to find a particular shortcut, the following list is laid out by palette name.
<font size=4>Alpha Palette (Alt+A) </font>
<font size=4>Color Palette (Alt+Z)</font>
<UL TYPE=SQUARE><LI>C Selects whatever color is under the cursor
<LI>Ctrl+F Fills Layer with currently selected color
[/list]
<font size=4>Document Palette (Alt+O)</font>
<UL TYPE=SQUARE><LI>Ctrl+O Open a Document
<LI>Ctrl+S Saves the Document
[/list]
<font size=4>Draw Palette (Alt+D)</font>
<UL TYPE=SQUARE><LI>D Brings up Depth slider at cursor location
<LI>I RGB Intensity slider appears at cursor location
<LI>Shift+I Z Intensity slider appears at cursor location
<LI>L Lock RGB and Z Intensity sliders
<LI>S Brings up Draw Size slider at cursor location
<LI>ALT While held down, toggles between Zadd and ZSub
[/list]
<font size=4>Edit Palette (Alt+E)</font><UL TYPE=SQUARE><LI>Ctrl+Z Undo
<LI>Ctrl+Shift+Z Redo
(Note that both functions are based on the mode that the user is in. If Transform>Edit Object is active, then will undo or redo the last change to the model. If it is not active, then they will undo or redo the last chnage to the canvas. Some changes, however, cannot be undone.)[/list]
<font size=4>Layer Palette (Alt+Y)</font>
<UL TYPE=SQUARE><LI>Ctrl+N Clears the active layer
<LI>Ctrl+F Fills the active layer with the currently selected material and color or texture.
<LI>Ctrl+B Bakes the layer shading
<LI>Shift+Click On any layer will toggle all layers on or off.
<LI>~+Click Selects the layer on which the clicked pixol resides
<LI>~+Drag Moves the layer contents. (Equal to Layer>Displace H and Layer>Displace V)
<LI>~+Alt+Drag Moves the layer content depth (Equal to Layer>Displace Z)
[/list]
<font size=4>Light Palette (Alt+L)</font>
<font size=4>Marker Palette (Alt+K)</font>
<font size=4>Material Palette (Alt+M)</font>
<font size=4>Movie Palette (Alt+V)</font><UL TYPE=SQUARE><LI>Ctrl+Shift+G Brings up Grab Frame slider at cursor position
<LI>Ctrl+Shift+O Starts continuous recording
<LI>Ctrl+Shift+P Plays ZMovie
<LI>Ctrl+Shift+W Select a Window
<LI>Ctrl+Shift+! Records a single frame
[/list]
<font size=4>Picker Palette (Alt+I)</font>
<font size=4>Preferences Palette (Alt+P)</font><UL TYPE=SQUARE><LI>F Quick 3D Edit
<LI>Shift+F Polyframe mode
<LI>Ctrl When Popup Info is turned on, hold down Ctrl to see even more detailed descriptions
<LI>Ctrl+Click On a Float Menu item, removes that item from the Float Menu
<LI>Ctrl+Drag Pull an item from the interface into the Float Menu. Items can be docked with otther items, or left floating separately
<LI>Ctrl+Shift+I Store Interface Configuration
<LI>Tab Toggles Float Menu on and off
[/list]
<font size=4>Render Palette (Alt+R)</font>
<UL TYPE=SQUARE><LI>Ctrl+R Render area around cursor
<LI>Ctrl+Shift+R Render All
[/list]
<font size=4>Stencil Palette (Alt+N)</font><UL TYPE=SQUARE><LI>Alt+H Turns Stencil on/off
<LI>Ctrl+H Hide/Show Stencil
<LI>Spacebar Bring up Coin Controller at cursor position
[/list]
<font size=4>Stroke Palette (Alt+S)</font><UL TYPE=SQUARE><LI>Ctrl+1 Replay last stroke
<LI>Ctrl+2 Replay all strokes
<LI>Ctrl+3 Record brush strokes
[/list]
<font size=4>Tablet Palette (Alt+B)</font>
<font size=4>Texture Palette (Alt+X)</font>
<font size=4>Tool Palette (Alt+T)</font><UL TYPE=SQUARE><LI>Ctrl+Shift+T Save the active tool
[/list]
<font size=4>Transform Palette (Alt+F)</font>
<UL TYPE=SQUARE><LI>E Scale
<LI>Q Draw pointer
<LI>R Rotate
<LI>T Edit Object
<LI>W Move
(Note that the above shortcuts can work be used together. For example, when Edit Object is not active, W will bring up the Move gyro. When Edit Object is active, W will enter Edit>Move mode.)<LI>M Create a marker
<LI>Ctrl+M Remove a marker
<LI>X X symmetry
<LI>Y Y symmetry
<LI>Z Z symmetry
<LI>Ctrl When Edit Object is active, hold down to paint a mask on the object
<LI>Ctrl+G 3D Copy
<LI>Shift Constrains object rotation when in Rotate or Edit Object mode
<LI>Shift+S Snapshot the current object
[/list]
<font size=4>Zoom Palette (Alt+W)</font>
<UL TYPE=SQUARE><LI>0 View actual size
<LI>+ Zoom In
<LI>- Zoom Out
<LI>Ctrl+0 Half-Sized, Antialiased view. After doing a best render, use this before exporting to save an antialiased image.
<LI>Spacebar+Drag Pans the canvas
[/list]
<font size=4>ZScript Palette (Alt+Z)</font><UL TYPE=SQUARE><LI>H Show/Hide ZScript window
<LI>Ctrl+U Reload a ZScript
<LI>Ctrl+Shift+L Load a ZScript
<LI>Left Arrow Load last ZScript
<LI>Right Arrow Load next ZScript (only works if you have used Left Arrow)
<LI>Up Arrow Scroll ZScript Up
<LI>Down Arrow Scroll ZScript Down
<LI>Esc Halt ZScript execution
[/list]
<font size=4>Special</font><UL TYPE=SQUARE><LI>Spacebar Brings up QuickMenu at cursor location
[/list]
