ZB4R6 - Custom Menu
Trying to create a custom UI and Menu set.
Enable custom UI
Attempting to reposition or delete by Ctl + Alt drag, the Draw size is creating duplicates of itself.
Brushes are readily accessed with the B key :wink: Some other stuff could be more useful on the screen. Mine as of a while ago can be viewed/downloaded here>> http://www.zbrushcentral.com/showthread.php?172590-Updated-UI&p=1075275&viewfull=1#post1075275
That’s what happens until you release the mouse.
What you can’t see is when out of edit custom UI mode there is a third Draw size slider.
It is actually duplicating, not just while holding down the LMB.
I restart ZB and go back to edit custom UI and works again for a little while, but eventually buttons will randomly stick, and start to duplicate.
not a huge issue or anthing, restart ZB is the only workaround for now.
That’s very strange. It just happens with the Draw Size slider?
Over the course of 10 min or so, it happens with different buttons.
