Win 7 64bit
ZBrush update 2 or the last one.
Press Cntrl+Alt click a brush, then choose a top row number key (for example) and ZB says the hotkey has been created. No hotkey is created. Hover over brush and the icon display gives a hotkey which does not work. Caps lock is not on.
The documentation says that the Hotkey file is in the C drive/ users/zbrush folder
I found the file in C/Users/Public/Public Documents/ZbrushData/ZStartup/Hotkeys. The file is called StartupHotkeys.TXT Zbrush writes my hotkey as a Poppup + whatever I press. The keys that work have no popup prefix. If I edit the prefix out and use the format that seems to work it still wont even after loading the file from within preferances / Hotkey area within ZB. Same spaces same format no joy. This is driving me nutz as no one else has this problem
Hotkey creation has always worked previously.
All help appreciated.
