ZB4 R2 - Crash when adding HDR image
When I try and load a .hdr image to use as a background image or through the normal Texture / Import menu, zbrush immediately crashes. Loading .jpg files works fine.
System:
OSX 10.7.1
8GB Ram
Richard
Tip: To load a background image, you may want to use the Light/Background sub palette instead of the Texture palette.
Thanks for including the info, we will have this tested.
Meanwhile, please use the .jpg file format.
Confirmed here in osx 10.7.1. I have attempted to load hdr files through the light/background side as well with the same result.
Cheers
Mike
Yes, me too, both through the Texture palette and through the Light/Background palette. Maybe a Mac thing, I’m running 10.6.8.
