One of the painful processes when doing hard surface stuff on ZB is
selecting precise polygon groups for creasing.
In ZB3 You Ctrl-Shift Drag to lasso, then release shift to hide polygons.
It hides all polygons that are ENTIRELY ENCLOSED by the selection area.
Polygons that overlap the selection area are NOT hidden.
In ZB4. You Ctrl-Shift Drag to lasso as before, but releasing shift has no
effect. OK, I figured out you have to hit Alt to remove polys.
BUT It removes all polys even partially overlapped by the selection. NOT
just polys totally enclosed by the selection.
So how in ZB4 do you remove a single polygon from the visible set of polys.
Edit: Or to put it more simply perhaps. How do you progressively hide
polygons?
G.
