Hello there,
I’ve customized ZB4 a bit by moving tools around and creating custom palettes, but in ZB4.2 when trying to save a custom UI it just doesn’t save. I am saving over the file manually in the startup folder as well as trying to CTRL + I function to save the Custom UI. I get the message which tells me ZB will use this UI as my startup UI but then it doesn’t ‘remember’ it. Also, I get an error when I go to point at a palette, say ‘tools’ and it comes up with the wrong palette.
I also noticed the screen isn’t properly expanding on startup but instead has to be minimized and maximized again to get it to ‘fit’ my monitor window. I’ve tried a few of the fixes with this included changing my screen resolution as recommended in the FAQ, but no fix. I also tried deleting my existing config but that caused me to have to re-authorize ZB.
Mainly, I’m really interested in getting ZB 4.2 to save my config file so I don’t have to load it manually every time.
Thanks!
Dan
