ZB3.5 Wacom Right Click draws new tool?
I have my front switch of my Wacom Stylus set to “right click.”
In ZB3.5, when I draw a tool and then use the front switch to activate the right click menu, a tiny, tiny new tool is drawn.
This did not happen in 3.1. Any tips to fix it?
It appears as if this happens with the mouse as well seeing as a right click now allows you to draw in 3.5.
I just tested this in 3.1 and it definitely does not happen.
I really hope this is a setting that can be turned off; it is screwing me up big time!
not sure if it will help but try changing your tablet button to the spacebar instead of right click.
Thanks, but that really isn’t the best solution to my problem.
I have a workflow that relies heavily on right clicking. If I can’t use that, I am sorely hampered. I have to go back to 3.1.
Why would such a dramatic change happen to ZB?
sorry to hear it, just out of curiosity, how does using the spacebar instead of right click hamper you?, i mean what does right click do that i’m missing?
It’s a workflow thing. I never used the spacebar before
But you used the right click on your pen? Then directing it to the keystrok SpaceBar for ZBrush is just like directing it to RMB. Just as I did. And no workflow hampered.
