ZB3.5 deformation>inflat bug
loading attached obj file and trying deformation>inflat doesn`t work
but doing so in ZB3.1 works fine.pls verify
test.zip (344 KB)
Works for me in 3.5r2.
Works for me in 3.5r2 also at the low-resolution, but this object file notes that “the topology has changed” (from the original?). Importing with hi-def detailing results in a disastrous mess.
Not sure what you started with (Oh…in 3.1: It’s a shirt.) Good luck. I’d offer more if I could.
That’s because you tried to import it into another live Polymesh object with levels of subdivision, probably the default polysphere. Let’s not confuse him even further :wink:
HIM?! What about me! ZB 3.5r2 gives the same message even when I don’t import on an existing polymesh (you’re right, that’s what I did. You’re not “Bingo” for nothing)
Splendor, he’s right. Slide by all the tech talk.
that helped:b2:
