ZB Startup - Prefs gone Wild
1) Where ae the ZB Prefs? I need to get ZB back to it’s default Startup.
2) How to delete or custom set the “Quick Pick” brushes?
- reset all brushes.
I don’t currently use a StartupDocument.zbr. Instead, macros are used for the Doc type needed.
After createing my Custom UI and save:
Peferences> Store Config
and
Save UI as: Custom_UI_Default.cfg
Close Zbrush, restart
ZBrush starts up with missing buttons: Active Points, Total Points, Double
is this the default startup file?
Peferences> Store Config> CustomUserInterface35.cfg
CustomUserInterface35.cfg is the startup UI that ZBrush automatically saves to when you use Ctrl+Shift+I to save the UI. This one will always load at launch, so should be deleted if you want to return to the default UI. Other UI’s can be saved to the ZStartup\UserInterfaceLayouts folder. You can then use the UI selector arrows in the Title Bar to move between them.
The Active Points and Total Points will only save correctly if they are placed while a non-3D Tool is selected. Here’s one of the threads about it: http://www.zbrushcentral.com/showthread.php?t=89423
Certain other features cannot be saved to a custom UI. I’m not sure if Double is one such.
