ZB crashes macbook sleep?
I’m not sure if it is an issue, but it seems when ZB is loaded with some tools, then I close the lid on my MBP, it wouldn’t go to sleep and when I reopen the lid, sometimes the MBP is still on and would hang.
Does anyone else have this kinda issue?
I don’t have that problem, but I run ZB on a MBP under Windows. Are you 100% certain it’s only when ZBrush is running? All I can sugggest is, make sure all your software and drivers are up to date, and check your power settings. If all of that stuff looks good and you can confirm that the issue is related specifically to ZBrush, give their tech support people a call.
Thanks for the advice, but the problem apparently also apparent when ZB is not loaded, although it started happening after i installed ZB.
I’m not sure what’s going on.
Thanks anyway.
