I updated to 4r8 p2 the other day when it was released and since then, any new projects I create will not save the Undo History.
I have created several new projects in p2 to test this and none of them appear to be saving Undo History. I have verified that the Preference is enabled and that I am saving the ZProject as I have in the past. I also made sure to follow the original upgrade instructions when moving from 4r7 and did a fresh install of 4r8. I did however use the ZUpgrader to update p1 to p2.
What is really strange is that I opened a project I started in 4r8 (before p1 or p2) and the Undo History loads fine from that file. I also made several changes to that same project to add to the Undo History and saved that file and those changes appear to load without a problem.
Based on that it appears p2 has the ability to load and save Undo History but will not do so if it is a brand new project created in p2.
If anyone has any help or advice, I would love some assistance in figuring this out.
Thanks
