In earlier versions of ZBrush we were able to actually access the smoothing brush. Now it just pops up a message saying that the smooth brush will be enabled when Shift is held down.
Okay, that’s all fine and good and all, but now it just uses the default smoothing sensitivity which I always thought was way too harsh. I used to be able to open the smooth brush and set its sensitivity down really low and then all other brushes would use that sensitivity level.
But now with not being able to actually access the smoothing brush itself, I can’t change its sensitivity, and it’s really getting annoying having to constantly readjust the sensitivity on the brush I’m using at the moment.
Is there some new way to adjust global smoothing sensitivity to affect all brushes?
I use a Wacom Intuos 3 tablet by the way and even just barely tapping to smooth can be too much, so maybe there’s a way to configure the tablet’s response to the smoothing brush on its own?
Thanks.
