Sorry if this has been answered elsewhere but after searching a long time I haven’t found an answer.
- In ZB 3.1, when I frame the visible part of a partially hidden object and turn it around, then the Brush Size is the same when Perspective is on : this is not the case in 3.5R3 : in R3 the Brush Draw Size “numerically” stays the same but “visually” it changes when I rotate the object
So I have to adjust the size time and time again : is this normal in R3 because I really preferred the behavior of 3.1?
On top of that, in R3 (with perspective on) the partially hidden object is zoomed out each time I click and drag to rotate it
? (This does not happen in 3.1) -
And one more thing : in R3 (with perspective on) when pressing the f-key for framing the partially hidden object, the object often disappears, so to get it back I have to unhide the hidden part and, frame it and then hide parts of it again. (This also does not happen in 3.1)
Anyone has experienced this?
I find it strange that I have not found anything about this at ZBrushCentral.
Thanks …
