ZB 3.5 r3 > Custom UI Right Tray
I have a few pallets docked to the right tray and I stored the UI config, but when I reopen ZBrush the pallets aren’t in the same order I saved them in. It looks like it’s sorting them alphabetically instead of how I had them. For example, lets say I want them in this order, top to bottom:
TOOLS
LAYER
STROKE
ALPHA
When I reopen ZB it does this:
ALPHA
LAYER
STROKE
TOOLS
Any ideas?
Hi Dustin…I also notice it…but what you can do is just simply save it again without doing anything with the reverse order, it should fix the problem (so you save the correct order > reopen ZBrush it will reverse it > save again the reversed one > reopen Z, and your UI will be like what you intended at first!)…I don’t know is it a bug or not, but for the mean time it works and an easy workaround so shouldn’t be a big problem :wink:
Cheers
_Revel
Wow, that actually worked. Thanks man!
Hehehh…any time man…For a people like me like to customize UI, this is kinda annoying at first, but after you know the workaround its quiet ok, but still…
Well lets hope this buggy thing will gone on the next release of Z4!
_Revel
